I will get some more pics and the tranny mount is bad I can shake it with my hand. So I’m going try changing the mount first thing. Thank u all. And I think it a 4” lift.
There's your problem. a 4" lift without having done anything to correct the now excessive angles at the front and rear of your driveshaft that is causing the u-joints on your driveshaft to vibrate... which is what you're feeling when you drive and especially when you accelerate.
4" of suspension lift, if that's what you have, is the magic number that when reached is the time to replace the rear driveshaft with a different type (called a double-cardan/aka CV (constant velocity) of driveshaft together with installing a SYE (slip yoke eliminator) into your transfer case to allow the replacement driveshaft to be used.
To keep the 4" of lift, I strongly recommend you get a SYE kit installed together with the double-cardan style driveshaft. And because a DC driveshaft requires a different pinion angle coming out of the rear axle, you need adjustable length control arm in the rear so the pinion angle can be adjusted to work with the DC driveshaft.
www.4xshaft.com can fixe you up with the right SYE kit and DC driveshaft.
If that's too much $$$ you can replace the 4" springs with shorter 2" or 3" springs but even that much lift can cause vibrations though on a milder/more easily corrected basis.
You can measure how much lift. The rear factory spring stock height is 8" and the front factory springs are 12" tall. Anything over that is from the suspension lift height. Like if your rear springs measured from top to bottom are 12" and fronts are 16" that means a 4" suspension lift.
