How do I get these off? Twist and pull doesn't work. The thread is smaller than the new ones for the replacement (upgrade) radiator. The new ones will push into the lines. Hoping they reach with the new fittings too.
Pull the hairpin out of the fitting.
You should be able to pull the hairpin out.Sorry, I don't see a hairpin. Explain like of five, please. The metal tube has a rib right before it meets the metal at the end of the hose.
You don’t! That is where the Dorman fitting would go onto your trans line instead of the piece with the quick connect in your hand.
I'm pretty certain this is the part you need.
https://www.amazon.com/dp/B000EPYHVO/?tag=wranglerorg-20
