Vacuum leak noise on deceleration
Reed18b
San Tan Valley, AZ
About a month ago I started getting a squealing noise on deceleration (sounds like a vacuum leak). I have not found any vacuum leaks, no codes being thrown. Jeep runs fine, just drives me crazy hearing the noise. Noise goes away as soon as I touch the accelerator. Any ideas?
What side of the motor. Mine was drivers side. Turned out to be the hose that goes to the brake booster.
Does it make any difference if you throw it into neutral/push in the clutch while decelerating? Trying to differentiate between driveline noises and engine noises.
