About 4 months ago I drove my jeep to a local off road park to let my 13 year old son drive offroad. Had no problem driving to the park and didn't realize I had a problem until I was on the road back home. I was having problems with an overheated battery so I didn't want to hook up my air compress to the battery to reinflate the tires. The local gas station was about 4 miles away. When I went to inflate the rear passenger tire I could fell heat before I even go close to the valve stem. Inflated the tires and drove to a local autozone. The vibration was bad. After not being able to figure out my problem I called my wife and father in law to drive my truck and trailer to come pick us up. I've replaced the passenger side caliper, pads and rotors, replaced the driver side calipers since I had to buy the pair. Replace all 4 brake lines (recall on the current lines). I replaced the axle shaft because it looked like the seal was leaking and the flange was wobbling enough to worry me. Still have vibrations starting around 35 mph. Before this trip I've had new rear driveshaft, rear pinion bearing replaced, new tires. Again, I felt nothing on the drive to the park, 2 hour drive and mostly interstate going 70 mph.
I guess my next step is to replace the driver side shaft since I already have it. This offroad park is a green level park, maybe one step above a gravel road/trail.
