Howdy everyone,
I am a little reluctant to post this while I am still working through the myriad of vibration posts. However, the constant theme in those are around lifts. My jeep is sitting on stock springs and older shocks (ranchos on the way). When I bought the Jeep I noticed a good bit of vibration that starts around 35mph in 3rd gear (I have 3.73 gears). Then the vibration goes away as I shift into the next gear but comes back at around 2600 to 2800 rpm. When at highway speeds (65 building to 70 mph) vibrations are non stop. The vibrations seemingly get stronger as you work your way through the gears.
My best description of the vibrations are that they are felt in the floor board and pedals. Not so much in the steering wheel. Feels pretty rear biased.
The suspension doesn't seem to be sagging. All control arms have been replaced with crown units (fresh bushings). Same with track bars. I have also replaced the u joints front and rear with spicer units. Additionally, I replaced the motor mounts and trans mount with crown replacements. Just replaced the wheels and tires. Had them balanced by a shop I trust and don't feel like that is it (though I am glad to have them rebalanced). My plan is to get the jeep into my garage tomorrow to get drive line angles but I have a hard time believing it would be that since it is bone stock. I also feel like driveshaft balance is something to look at though it seems unlikely with how stubby this is.
Has anyone faced this with a stock TJ? I feel like I am taking the right steps but I am far from a Jeep expert let alone a TJ expert.
Thank you all and I will get those drive line angles posted when I have them.
