Warn M8274 (I think)
Test motor like this. Avoid remote and solenoids, can test them later ?
Motor running is the main thing, they are near 300 bucks now.
Reactions: John Cooper
That whole metal plate is your end plate.. It wasn't in your other pictures that I saw.
If it's a working winch it's worth that much...
You can run it for a short time with no oil in the bottom housing. The seals go bad and people run them with next to no oil in them.
I hooked it up, shocked myself, and then used the remote. Backwards works. Forwards makes a clicking solenoid sound.
Used with questionable solenoids easily go for $400 around here. If you want to figure out which solenoid it is and replace it it a good working 8274 can fetch $600. Remember they are over $3k new.
How about swapping from solenoid to contractor?
Down here you can pickup a good working one for around $500.00 one that needs work $75.00 to $350.00 depending
I am just guessing its the solenoid. The motor works backwards and forwards, but when using the remote, it makes that click sound when trying to unreal.
Your decision on selling, personally I would advertise it and let folks know what it does and see where it leads.
