Every now and then my carpet on the passenger side gets wet and I wonder where the hell this leak is coming from. I think I finally found it but I’m not sure. Is this a known problem ?
1st photo under the wiper motor, that rectangular hole empties in to a funnel-shaped piece of plastic. At the bottom of the funnel (on mine anyway) are 2 rubber flaps attached. On mine, the bottom of the funnel was clogged with stuff.
Did you also check at the passenger side al the way in the back by the feet up the foamy seal ( dont know the name )..is it wet ? I have a 97 TJ and the water that is on the top of mash part of the cowl and the wind sometimes makes it drip in and around the air intake. I believe that water comes in and around the air intake under the cowl ( your picture 2 ) and drips inside and goes to the lowest point. that is the foam seal what i mean around the plastic cover at the back of the passenger side..
Strange thing when the blower is at the "feet stand " is much worse..
I had this from a video i found on youtube from a American TJ owner with the same problem. I will try to find it again..
( sorry for my English when it is not correct )
