What’s is my LJ worth?
Michael8nuts
Vancouver Island
I’m just wanting to get an idea what my 2006 LJ is working at the moment in US dollars. Thank you
automatic transmission, 3o8,oookm/192,000miles,burns no oil, no oil leaks, runs excellent,no rust, new front fenders, 6” flares, front ball joints and front axle u-joints (winter 2o21), new left front wheel hub (summer 2o2o),new radiator,water pump, thermostat, timing chain and gears (summer 2019), tummy tuck, Rough Country low profile tranny mount that has been re-enforced with two 1/4” angle iron pieces (supports vehicle weight), brand new Cooper stt pro 35” tires on ProComp 69 15x8 wheels, spare is a 16” ProComp 69 16x8 with a new Deep Digger 35” tire, corner guards with round led tail lights, halo led headlights, new winch bumper (winter 2o21), smittybilt 95oolb winch with synthetic rope, rear view camera with screen, both seats lifted 2”, bielstein 51oo shocks, Rock Krawler 2” suspension lift springs with front upper and lower adjustable control arms, 1” body lift, custom rear bumper with winch points, custom sliders, rocker guard and belly armour, two led pod lights, front and rear Aussie lockers, 4:88 gears, 1 ton tie rods, adjustable front track bar, Rampage soft top (frameless), hard top without damage, grab handles, mesh top,most of the carpet is out of it, frame rails have been cleaned out(sand/dirt) and all frame holes are covered up with eternabond tape so no water/dirt can get in, new fan switch panel and fan resistor, magna flow muffler, no cats, 1/2 doors with new uppers, Rock Jock anti roll bar, no accidents
The mods don't mean much. Not being mean but mods are tough to recoup money from.
A lot of people like to build it "their" way and all those mods can hurt.
Luckily it doesn't sound terribly extreme but you've basically took all the modifications away by doing so much already. You might be able to find a buyer that doesn't know the box end of a wrench from the open end and would rather buy a built Jeep than build it.
But....most of those buyers are going the 4 door JK route.
Find a couple comparable jeeps... year and condition... unmodified and that will give you an idea your value. Those new replacement parts mean nothing. It's used wuth 192k on the clock. New wheel bearing hub? Who cares.
Again... not being nasty but just giving you a realistic opinion.
Reactions: TWiG01
Well, ive been considering selling and , i do have an opportunity:
a friend just bought a Rubicon LJ and he want all my parts. Id get all the stock bits. Id have to leave the body armour as it’s drilled through the body.
i’m just not sure if it’s worth the labor. When I crunch the numbers it kind of depends on what people will pay for the stockish Jeep
Post more pictures
Bryan Adams moved to London.
Sorry, that just kills it.
would need to see more pics, and how much rust is present, but in the spring and summer around here you could probably get around 12 to 13k because its an LJ
