Hey, everyone! I didn't see an introduction section, so I thought I would include a quick wave here! :hello:
I've been dealing with a rattling noise on acceleration for quite sometime and could use your knowledgeable guesses as to what the issue may be, or at least where it could be coming from so I can probe it further.
As I mentioned, the rattling noise occurs only when I use the accelerator and it doesn't matter how fast the Jeep is going. Even on the highway, I can hear the rattling loud and clear. I hear it almost directly under my foot in the driver's seat, and it seems to be coming from the front rather than the back.
I went underneath to check for any lose components within reach, such as the heat shield, and everything from the outside appears tight with no play.
My guess is that the rattling is coming from the exhaust system since the noise only occurs the moment I use the accelerator. The rattling noise could be described almost as broken metal pieces moving around and being disturbed.
I know it's difficult to discern such a common and ambiguous issue with just words, but maybe someone has dealt with a similar issue and found a solution. At this point, any suggestion is better than none! Thanks in advance!
