Hi I'm new member here just bought my 2001 wrangler looking to do a 3 inch lift I don't know what to buy, bought the jeep with spacers but don't like the way it rides
Can you send me the link to the parts you bought and hows the ride? Any rubbingDo what I just did. Pro comp 2” springs, all new stock control arms and, Rancho 5000x shocks. All in $550.
If it's making noise when turning, then exchanging spacers for longer springs will not change that. For the bouncy ride, new proper length shocks will fix that.The ride right now its bouncy and don't like it and when I turn the steering wheel all the way to one side makes noises in the back aswell as in the front , I was looking at rough country, ebay kits but they all different dont know really what to buy
I know I said 32s but the number one the tires are 33x12.50R15ltIf it's making noise when turning, then exchanging spacers for longer springs will not change that. For the bouncy ride, new proper length shocks will fix that.
What size tires are on it (I know you said 32's, but what's the actual size) and what is the tire pressure set at?
OK, for the tire pressure, somewhere around 26-28 psi (depending on vehicle load) is a good range.I know I said 32s but the number one the tires are 33x12.50R15lt
I currently im on 2 inch spacers but don't like the ride. If you have stock shocks (too short) or Rough Country shocks, that's the problem with the ride. BB spacers don't make it ride bad.
I ordered the control arms from Summit Racing. They were on sale for $170.00. I also had a coupon for $25 off my order so they ended up at $145 plus tax. The springs and shocks were ordered off Amazon. I also caught the springs on sale at $ 200 for both sets. The Rancho shocks and stabilizer were $238 I think. That also included the steering stabilizer in the set. Make sure you get the 0 to 2 inch lift shocks. I’m running 31’s and had to adjust my steering stops to eliminate the rub on the lower control arm. The ride is great with the Rancho shocks. My avatar is 2 years old that’s a 4 inch lift with 35’s.Can you send me the link to the parts you bought and hows the ride? Any rubbing
Thankshttps://wranglertjforum.com/threads/a-beginners-guide-to-lifting-your-jeep-wrangler-tj.733/This is a great thread on suspension lifts
