Back to the OP's original concern here's a reference for load index ratings
Load Rating
The load rating is often found after the size numbers in the tire size of passenger car tires. A P195/60R15 87S would have a load rating of 87.
Load Index (E.T.R.T.O. 1991 - Section 13)
Code Pounds Kilograms Code Pounds Kilograms Code Pounds Kilograms Code Pounds Kilograms60 551 250 80 992 450 100 1,764 800 120 3,087 1,40061 567 257 81 1,019 462 101 1,819 825 121 3,197 1,45062 584 265 82 1,047 475 102 1,874 850 122 3,306 1,50063 600 272 83 1,074 487 103 1,929 875 123 3,418 1,55064 617 280 84 1,102 500 104 1,984 900 124 3,528 1,60065 640 290 85 1,135 515 105 2,039 925 125 3,638 1,65066 661 300 86 1,168 530 106 2,094 950 67 677 307 87 1,201 545 107 2,149 975 68 695 315 88 1,235 560 108 2,205 1,000 69 717 325 89 1,279 580 109 2,271 1,030 70 738 335 90 1,323 600 110 2,337 1,060 71 761 345 91 1,356 615 111 2,403 1,090 72 783 355 92 1,389 630 112 2,470 1,120 73 805 365 93 1,433 650 113 2,536 1,150 74 827 375 94 1,477 670 114 2,601 1,180 75 853 387 95 1,521 690 115 2,679 1,215 76 882 400 96 1,565 710 116 2,756 1,250 77 908 412 97 1,609 730 117 2,833 1,285 78 937 425 98 1,653 750 118 2,910 1,320 79 963 437 99 1,709 775 119 2,999 1,360
Load Range
Load range is used on light truck tires and indicates ply rating and load pressure (PSI).
Load Range Ply Rating Load Pressure (PSI)B 4 35C 6 50D 8 65E 10 80F 12 95
***Thank you. This explains alot of my confusion. I think I'm looking at passenger tires and LT tires. Which apparently use two different systems of measurement for a load rating. So there is no comparison chart showing which ratings are the same between a passenger and LT tire. So that you could compare the two.***
I'm seriously considering the Falkens in my original post. They have great reviews. And are C rated. At least going by tech reviews I've read. It's not an LT tire though. And has a thinner sidewall. But I'm no rock crawler. And they seem to last as long if not longer (most reviews show they last longer) than the Ko2's for twice the price. It's either that or the Coopers. Which look like passenger tires to me.
Here's a good review comparing the Falkens to Ko2's:
https://4wdlife.com/falken-wildpeak-at3w-vs-bfg-ko2
Either that or a set of Ko2 take offs in like new condition. Yet to be found. But lots of ads on CL for similar. Unfortunately they come usually with Newer JK rims. Which pushes the price to high. I wish I had another grand for Ko2's. But they only slightly edge out the Falkens. The Falkens might even last longer. But the Ko2's work slightly better in the rain. The review above rates them both about the same. But again, the Falken is half the price.
Thanks again for posting this. It's clears up my confusion. I was trying to compare passenger tires with LT tires.
