M Mikey Mike New Member Joined Feb 6, 2022 Messages 7 Location Sapulpa, Oklahoma Jul 9, 2022 #1 What is this under my dash? 2000 tj
97JadeTJ TJ Enthusiast Supporting Member Joined Aug 14, 2020 Messages 784 Location Hot Springs, AR Jul 9, 2022 #2 Appears to be the airbag control module…
OP M Mikey Mike New Member Joined Feb 6, 2022 Messages 7 Location Sapulpa, Oklahoma Jul 9, 2022 #3 97JadeTJ said: Appears to be the airbag control module… Click to expand... Thanks. Also found this wire dangling under the drivers side dash. FYI I’m a new jeep owner.
97JadeTJ TJ Enthusiast Supporting Member Joined Aug 14, 2020 Messages 784 Location Hot Springs, AR Jul 9, 2022 #4 Light bulb plug?
V Vinman TJ Enthusiast Joined Sep 20, 2018 Messages 992 Location Calgary, Alberta Jul 9, 2022 #5 Mikey Mike said: Thanks. Also found this wire dangling under the drivers side dash. FYI I’m a new jeep owner. View attachment 341734 View attachment 341735 Click to expand... Gear shift position indicator light if you had an auto transmission Reactions: 97JadeTJ
mrblaine Crew Member Supporting Member Joined Nov 20, 2015 Messages 29,083 Location Quail Valley, CA Jul 9, 2022 #6 Vinman said: Gear shift position indicator light if you had an auto transmission Click to expand... Correct. Typically folded back and taped to the harness in the manual rigs.
OP M Mikey Mike New Member Joined Feb 6, 2022 Messages 7 Location Sapulpa, Oklahoma Jul 9, 2022 #7 Thanks
