I was able to connect the mightyvac to the gauge, was able to pull 30lbs, both gauges matched along the way = gauge confirmed to be working.
Just looked, everything appears to be connected, all the way over to the connection on the manifold.
The hose to the reservoir has a crack on the boot. I unplugged it from the reservoir and plugged it with a golf tee, but that doesn't seem to affect operation. I'm going to double check those tests here in a little bit. Is there a good replacement for this boot/hose, or do I just get some hose from the parts store and cobble together fittings to get the sizes right?
Here is an assortment. Check the line right at the firewall I have found a lot of leaks there, bend the hose a bit to look for cracks.
https://www.amazon.com/dp/B002H9FBL0/?tag=wranglerorg-20
