Which LED flasher relay do I need?
1955migu
I upgraded my 2001 Jeep Wrangler by replacing all lights to LED.
I became aware of the hyperblinking, so I started searching for the correct relay.
I found a Novita EV-27 on Autozone which is at 15 mins from home.
I read about a GCD-TJ0106.
My electromechanical reported me that LEDs work OK but that hazard lights are not working. Is this common? Do I need to buy the GCD and replace the Novita?
Thanks.
A similar discussion was posted the 2nd week of July by a member from Canada and depending upon how the circuit is wired; will determine which relay will work in their application.
https://wranglertjforum.com/threads/turn-signal-and-fuse-keeps-popping.63729/
I don’t see anything special in that thread. EP27 is known to blow fuses or keep the turn signal running if you have it blinking and shut the motor off. LM470 is known to be the simple relay replacement for 01-06. The only reason it didn’t initially work for that guy is because he had resistors wired in. There was no need for resistors and they were making the situation worse.
The point that I was trying to make was that there could be information in that thread that may assist the OP with his problem.
I never did understand the resistor solution...lets see I can go to any parts store In the world and buy a plug and play flasher or I can spend a bunch of time cutting factory wiring and making questionable connections which will corrode and give me issues in a couple years
Reactions: JMT and CharlesHS
They aren't a terrible solution. The flasher is certainly easier, although aftermarket flashers can be finicky. I've seen some say the EP26 and LM470 flashers have some inconsistent blink rates. Not sure why that is but I don't ever see that complaint about the factory flasher. So I can see some merit to keeping the factory flasher and wiring in resistors to take the place of bulbs.
Modern vehicles all have computer controlled flash rates that are based on monitoring amp draw and they will speed up or keep the blink normally depending on the load realized. So on a modern vehicle if you are replacing glass bulbs with LEDs, you HAVE to use resistors, or use crappy bulbs that have resistors built in (usually fail after a while due to all the heat killing the bulb).
I'd say the success level is directly proportionate to the competency of the installer and the connectors they use. If you use good splices with a tool that crimps them tight and follow up with good weatherproof heat shrink, you're highly unlikely to induce failure, not more than anything stock anyways. If you go in there with scotchlok or t-tap connectors and wrap them with some crappy electrical tape to seal them, then yeah don't expect that to last.
As for install time, it depends on how easy the wiring is to get to but I can install resistors pretty quick. I also try to install them on anything that isn't permanent if possible. For example if I were changing tail lights and wanted to do resistors, I would wire the resistors to the tail light harness, not the Jeep harness leading up to the lights. That way the resistors are localized to the tail lights themselves. If you ever have to replace a tail light then sure that adds some work but not much and keeps all the custom hackery on the part, not the vehicle.
Reactions: CharlesHS
I disassemble alot of jeeps and you know what I see 95 percent of the time? Twist and tape or scotch lock connectors..I hold myself to higher standards but alot of people wont/don't
  • Sad
Reactions: JMT
True. For anyone who can’t do a decent wiring job, resistors are a bad idea.
Reactions: P man
