I have a 99 Wrangler Sport and started noticing coolant loss a few weeks ago. My commute to work is about 20min and when I'd come home in the evening the top of the radiator would be wet with coolant which looked like it was also hitting the belt and spraying onto the rest of the engine.
I tried replacing the cap first but the issue continued, so I assumed it was the radiator itself (was the original radiator) so decided to refresh the whole cooling system.
I ended up replacing:
Since having done this, the temperature gauge hasn't gone above 190 (was running around 210-220 previously), but about 1 minute after stopping and killing the engine, a slow trickle of white smoke (possibly steam?) starts to come out from underneath the radiator cap. Not a lot, and not noticeable without the hood popped, but definitely there.
Any ideas? Possible the system is losing pressure somewhere even though otherwise it seems to be running fine now?
- The radiator (with a mopar)
- Radiator cap (also 18lb mopar)
- Both hoses connected to the radiator
- Both hoses running to the heater core
- Thermostat housing + gasket
- Thermostat (stant)
- Temperature sensor
- Line running to the overflow reservoir
