UPDATE: Changed to Tridon CA18125 (Correct 18psi Rad cap) and it's helped a lot.... still seems to be super hot, hoses and radiator is too hot to touch after driving. Still boils, but only slightly when I switch off. 100 degrees today also.
EDIT: is my cap the wrong one? I'm using a Tridon Recovery Radiator Cap CA16110. The alternative one they said I could use was a CA18125. I'm in Australia, not sure if you have these brands in US.
My TJ has 65,000km, just bought it, it was running hot when I bought it, weather has been 100 degrees f+ last week .... I replaced all the following with brand new just to be sure:
- Radiator (alum) + new 16psi cap (Switched for 18psi cap which helped)
- Water pump
- Thermostat
- Radiator hoses
- Heater hoses
- Heater core bypassed
- Gave it a good flush, all new coolant
Radiator is boiling, but stops boiling when I push down on radiator cap. Temp gauge shows 100-105 degrees Celsius constant. Mechanic looked at fan clutch and he said it's spinning fine. is it just my cap? Coolant is going into overflow bottle and returning when it cools down. Thanks
When I replaced everything in my cooling system it also overheated, bigly. As soon as I burped the system and got all the air out, problem solved. I live in So. Cal high desert and it gets up above 110 deg. and, except for that one time when I had air in the system, I don't have any issues with overheating.The spotlights shouldn’t be an issue the clutch fan will pull the air that it needs if it’s operating properly and the shroud is in place, a fan doesn’t do much above 35 mph vehicle speed. Did the system get “burped” of all the air?
That's perfectly normal, the engine is 210f and it's located immediately underneath the uninsulated hood. Also the radiator is of course going to be WAY too hot to touch shortly after the engine is running.I'm also in Perth. Temp gauge showed half, maybe a few degrees over today but that's it. It's more the under bonnet heat just seems hotter than any car I've owned. I checked for bubbles when I bought it, nothing at all, still nothing. I've seen bubbles from bad head gasket before on other cars, none of that in my TJ.
I renewed the cooling system because It was hot to touch the bonnet when I test drove it.
My mechanic said it was spinning ok. Cost of clutch fan was insane here so I left that, but maybe I should swap it out after all. When it overheated the other day, the fan was able to be turned with minimal-medium effort and it was not locked, so maybe I should get a new one. Can I just get a bolt on fan and do away with the clutch, seems like a mighty waste of money?I read original post and it said fan clutch spins fine ? As it heats up it should get harder to spin or lock up when temp overheats. All the stuff you have replaced I can't believe you haven't replaced fan clutch ! Does it overheat while cruising or at idle ? When you shut it off hot is it hard to spin fan ?
Brand new cap, water level was down in the overflow and I've topped up once in a month, and I just really kept an eye on overflow bottle level, so radiator level could have been down and I didn't notice. I still suspect head gasket even though no bubbles and done chemical test myself.... coolants going somewhere. When it boiled over the other day spewing coolant out the overflow bottle, it ended up needing 1.5 liters of coolant when it finally cooled down.Agreed, but it boiling over isn't supposed to happen. It's too hot unless he just had no rad cap on it at all.
Clutch fan ordered $100. Will try that. All this time I was thinking they were $500+ due to website price error.I read original post and it said fan clutch spins fine ? As it heats up it should get harder to spin or lock up when temp overheats. All the stuff you have replaced I can't believe you haven't replaced fan clutch ! Does it overheat while cruising or at idle ? When you shut it off hot is it hard to spin fan ?
Yeah I can imagine the air is eddying around those big spotlights and not efficiently passing through radiator, they actually take up nearly half the grill space.Defiantly something wrong John I drove yesterday in the Perth heat and then again today , It was 42c (107) at 430pm and my gauge didnt go over half.
I would remove them big spotlights first as you only seem to overheat on really hot days, flowing air temp today and yesterday were much hotter in my TJ than the still air and the reason I wont go topless.
Those 7 big oblong holes in the front grill are there for a reason, blocked air flow can be the same as a blocked radiator.
Also did you have your A/C on full? Is the heater working?
I had a HQ (Chevy) 6 cylinder years ago that came with a Yellow Terror head when I bought it, it used to get so hot the headers would sometimes glow and melt the positive wire to the starter causing the starter to engage, when I finally took the head off the gasket had been put on round the wrong way blocking some of the water jacket holes! Thats why it was overheating but showing no sighs of a blown head gasket or cracked head.
If its not the lights blocking air flow then it could still be the thermostat not always opening. If it was a blown head gasket it would overheat regardless not just on super hot days.
Check your harmonic balancer.
Yes, all I could get. I live in Australia. Maybe will order Mopar, are they copper?He did say that he put an aluminium radiator in it. Most here would say get a Mopar rad.
No it does not get hot idling or on highway (gauge wise), its at 100 degress (celsius).... I can feel incredible heat coming through the firewall and under the gearbox, I even put thermal insulation under there to minimize it.They are aluminum. That's not your problem though. You never answered my question if it gets hot driving at highway speeds or just at idle/city driving.
So it doesn't overheat while running, either at idle or at speed, but it's boiling over when you shut it off? It would only do that because it's either too hot or the system isn't pressurized like it's supposed to be.
So your know anybody with a coolant pressure tester kit?
This^^. Boiling after shut off is definately a sign of loosing pressure somewhere. Pressure drops, lowering the boiling point of the coolant, and it starts to boil. Most likely the cap. I believe you said you had replaced that as well, but it sure sounds like a cap problem. Did you get the correct 18 pound cap?So it doesn't overheat while running, either at idle or at speed, but it's boiling over when you shut it off? It would only do that because it's either too hot or the system isn't pressurized like it's supposed to be.
