I replaced my TJ hood with an aftermarket one. It only has one windshield washer squirter hole right in the center of the hood. Where do I find a single squirter to fit this hole?
Couldn't you combine both fluid hoses into one fitting and route it to the lone spritzer? I would think you'd get a heckuva squirt.
Or have fun with it. Route one hose to the single spritzer and extend the 2nd hose to the rear bumper with a custom hidden spritzer so you can squirt impatient idiots who tailgate you.
My Jeep's "Single Spritzer" doesn't hit part of the glass as you can see on the picture.
The bottom 1/4 of the glass is dry and the left wiper blade doesn't bring water from the rest of the windshield, whatever speed I drive.
Americans set the spray to work at freeway speeds but far and away the best I've found is on my Tundra which has an even spray pattern across the entire windshield about 1/3 the way up so the wipers get a full load of water both ways.
The old pin in the nozzle adjustment and trying to raise the entire unit doesn't work.
