Reviving this one again.
I’m getting around to doing the swap and getting the remainder of my parts rounded up.
The yokes on the 231 output shafts have the same splines and shaft size however the 241 uses a stepped seal surface so the 231 seal should fix that.
Is there any reason one couldn’t use the 231 yokes on the 241? I have double carden drive shafts so I’m sure the 231 yokes aren’t stock.
