Hello Fellow Members,
First, I want to thank @hosejockey61 for his amazing instructions on axle rebuilds & locker installs.
I am doing this exact setup from his video - with ARB locker, Revolut gears, and HP dana 30 from XJ.
The problem I encountered is the following:
after setting up pinion depth with a setup race (actually also with setup outer pinion bearing too [with filed down the inner surface of the bearing]), I have set up pinion preload using setup nut to the correct range of 15-20 in-pounds.
I have then inserted the final (a.k.a. non-setup) inner bearing race with all the shims; and using final (a.k.a. non-setup) outer bearing + baffle + oil ring have put everything together with the final new oval pinion nut.
This is where the problem appeared. At around 180 ftlb on the pinion nut, my pinion rotational torque is much lower than previously recorded 15-20 inlb... it's minuscule at <5.
Aside from the fact it is very frustrating, I am not sure what could have caused it...
I guess this is my first question - possible cause..
a. Is there a washer under the pinion nut (I was not taking the axle apart myself, so not sure how it was set up). In the video above @hosejockey61 does use a washer; however, in a separate thread, he mentions not to use a washer with the oval nut.
b. how do I assess the damage done by the oval but to the pinion threads? I am OK to remove the nut, and then be safe to put a new oval nut onto the thread (obviously at the end of the process, not during the setup).
Thank you all!
- Difference in setup vs final race/bearing (although unlikely - both were new);
- Maybe the one-time-use oval nut was too sharp (+ I used brake cleaner to clean the threads on the pinion); and the nut is not all the way it (again, very unlikely, as then I use a pneumatic impact wrench, I hear the distinct metal sound, and the nut is no longer rotating).
- remove the nut, disassemble, and re-do the preload shimming process to get the correct value (+ use new oval nut at the end + new oil seal)
- something else? (maybe something else I can check before I start no.1)
Thank you all!
