I have kmc aluminum beadlocks machete on my Jeep JKU and want to put those rims on my TJ. A TJ Sport wouldn't be able to run 35" tires would it? I was thinking of using adapters but i've read adapters are bad and if i'm already risking it with 35" then I might as well change axles.
What is the most common/easiest swap to do that would allow me to use 5x5 and <38" tires but isnt to expensive? I'm building my TJ to really only be used for offroading so I might just get 38" tires instead of the 35" tires from my JKU. I'm also in the process of installing overline fenders so the only fitment issue would be the axles.
I'd also like to install lockers on it.
