To all,
I have been dealing with an ongoing transmission leak. At first i thought that the pan was not sealing and leaking from there, but that is not it. Today I removed the transfer case to replace that seal at the back of the transmission. I noted that there was not a gasket there, but I am getting one before putting back together. I then noticed that there may be another leak, which looks to be between the transmission and the extension, or whatever that six inch or so thing is that is between the transmission and the transfer case. It is sorta square and is held on by I think 6 bolts.
My question is, is there a seal and/or gasket between the transmission and this extension that can be replaced? I do believe there is a leak there. If there is anything to replace, how hard is it to remove this extension? Are there clips and such to remove on the shaft before the extension can slide off? I have googled 32RH diagram, but the ones that come up really do not explain what it takes to remove the extension and if there is anything in there that could be wore out and leaking. Thanks for any help.
EDIT: the extension is called the ADAPTER EXTENSION, and I am putting a new seal in it, but what is on the other side of this extension and can it leak?
