Comm gear surviving an EMP, any ideas?
Nuclear pulses are very big so small things like the steel hull of a nuclear sub are not large enough to stop damage. Lightning pulses are small so good grounds easily reroute the energy preventing damage. When people talk about Faraday cages and foil hats that's fine for small stuff but big stuff rolls on through.
What is the expected wave length of nuke pulse? How about a dirty nuke?
Here’s the thing… a radio only works if there is another to receive/send. So basically you would be reliant on others to protect theirs the same, and the likely hood of that is probably so close zero that it would be immeasurable.
But my answer… similar to a bomb bunker. Put it in a weather tight box with chicken wire around it (faraday cage) and bury it 9ft under ground. Or run something like this, if you trust it.
https://www.empshield.com/product/v...NCeTZo2ukjkh-zOmUpsjL0CJwUwXzGVxoC3zAQAvD_BwE
Also I don’t believe there is a way to protect them without making them inoperable while protected.
Reactions: WSS
That seems to be the general consensus. I plan to build a spare repeater and store it with a few radios JIC
My Intent is to have a working local repeater and a handful of programmed matching radios that can be deployed in minutes if needed. Rotating working repeaters is good practice I think to keep trained.
2 is one and one is none, especially if one is in use or unshielded when the balloon goes up
And to think that some of these guys got on my case for having body armor and wanting to be prepared :LOL:
Not on your case about the armor, just the cost, but that's only because of my means. If I had the means, I'd have a full military kit!!!
Reactions: WSS and Chris
I'm disappointed, you guys are overthinking it. :p
Solar panels
So your Faraday Cage will need to be big enough for the repeater, radios, batteries, charge controller, and probably your panels too.
What’s the location of the existing repeater? The ones around me are on water towers and are difficult to get to.
