Hello, I just bought a set of 4 Rubicon Express 4.5 inch springs with some Rancho's RS5000X, my TJR 2006 already had a lift kit when I got it, front total 4 inches by springs and a 2 inch lift puck and rear 3 inches with only the springs, (16 inches front and 11 inches rear according to the TJ lift chart) it has the 4 non-adjustable skyjacker lower control arms and the 2 upper front control arms so I'm trying to get rid of all skyjacker stuff and I started with the springs... my TJR has the rear bracket for the relocation of the rear track bar, the drill in the front for the stock track bar to be relocated (the wheels are pretty much aligned) and I add some washers in the TC to eliminate vibration..
The 64,000 question would be.... in most-important vs can-wait-a-little-longer scale... what would be first... to get a new front adjustable track bar, to get a rear adjustable upper control arms to adjust the pinion angle (current I have stock upper rear control arms) and may reduce vibration, to add a MML, save some money for the double cardan DS (since it is a rubicon, no SYE will be needed) or start replacing the non-adjustable lower control arms from skyjacker..
Extra info:
- I dont know what lower control arms are the ones in my rig (I know they are skyjacker but I dont know what size or model)
- I have skyjacker quick-disconnect in the front sway bar so no issues there
- I did get a new set of rear sway bar links for the 4 inch lift
- I may have some vibration (not that bad) but since the TJ has always been like that and that's the only jeep I have ever driven, I have no point of comparison
- It is my DD and I'm a weekend warrior but, where I live is really small so I dont usually drive more than 6 miles to get anywhere.. maybe once per month I drive more than 40 mph, the rest is really slow
- I measured with an angle app in my phone and the angles from my pinion and driveshaft were 22 degrees vs 11 degrees (something like that)
- The TC drop are only 4 washers, less than half an inch
Extra info:
