I replaced the stock rear sway bar and links with a heavier sway bar and links with heim joints at both ends. After installing I have noticed a popping noise when wheeling and have isolated it to the sway bar links. I believe I have adjusted them correctly and tightened the jam nuts, but I can turn the shafts by hand and this causes the heim joints to rotate and make the clicking popping sound. Is this a poor design? Perhaps I should just replace the links with the solid type (no heim joints) . Any advice?!
