Thanks for the add!! I am new to the Jeep scene. Have an '03 hardtop. Wonder how to prevent moisture from building up/collecting inside? What is the best remedy for mildew?
Me too. Snowing like ×%♤* here now.Thank you for the feedback!! I know it is not the heater core, but will check all the seals. I'll do the lysol for now too. It is not a good time of year around here to dry to dry anything out. Cannot wait for spring!!
I had a 01 with a hard top and right where your back glass and tailgate meet is a bad place for leaks well at least mine wasThank you for the feedback!! I know it is not the heater core, but will check all the seals. I'll do the lysol for now too. It is not a good time of year around here to dry to dry anything out. Cannot wait for spring!!
We are not getting the snow right now, but have been unseasonably wet1Me too. Snowing like ×%♤* here now.
The seals are not that much for a replacement oneYes!! Had to put a nerf ball on the spare tire to hold things tight.
A TJ roof is a single layer of fibreglass. If you live in a coastal or high humidity environment you will see condensation. No way out. Heated garage? Plug in heater? But if you park outside? The dew on the outside will also form on the inside.... only out is to add heat.Thanks for the add!! I am new to the Jeep scene. Have an '03 hardtop. Wonder how to prevent moisture from building up/collecting inside? What is the best remedy for mildew?
Biggs, Umatilla, or maybe Bend?In a little po dunk town 140 miles east of Portland, Oregon. It's been wet even for the desert.
Hmmm. My 80s CJ had multiple layers, my 91 YJ, had multiple layers, my 95 YJ had multiple layers, my 2000 TJ had multiple layers, my 05 LJ has multiple layers. Are the different north of the 49th?A TJ roof is a single layer of fibreglass. If you live in a coastal or high humidity environment you will see condensation. No way out. Heated garage? Plug in heater? But if you park outside? The dew on the outside will also form on the inside.... only out is to add heat.
Must not hunt pheasants.![]()
