Let's here what you've done to your TJ today!
I'll start by saying I gave her the biggest, most thorough cleaning possible!
I changed my plugs and put on this new coil.
Did the tailgate string mod...
This might displace seat risers from 'favorite mod' status.
Also finished the Auxbeam 8 switch panel. With all the button labels on, the panel is as obnoxiously bright, but I still prefer it at the dimmest setting. Hid a momentary switch near the headlight switch. Forgot to take a picture of it. I'll be doing a write-up on this shortly.
Can’t wait to see your write up!
What, exactly is the string mod? Never heard of it.
Spent a whopping 26 cents on a 5/16x1 bolt and lock washer, put it in the stripped hole and SNUGGED it and the rest of the diff cover bolts. Filled the diff with gear lube, it took a little over a quart.
Took a short test drive and the Powertrax No-slip seemed to perform as promised.
Fitted the Crown heavy duty steering I have had sitting around in the garage for a few months.
Is that the kit that comes with the steering stabilizer, or did you re-use the stock one? I bent my tie rod a few weeks back and I've been looking at those, but I just replaced the stabilizer like 6 month ago.
Someone posted this a few days ago.
Once the tailgate is unlocked and opened, you tug the string to lock the gate without having to use the key. I’m forever turning the key one way and the other to lock the gate with the key. Can’t remember if it’s left to lock or right.
Kind of silly but I love it!
Today I did this…turned 70,000 miles
Reactions: TheBoogieman
