well aware. just dont want anyone to get the idea that running even 35s the right way is a cheap endeavor.Right, but at the very least you can keep the axles. Once you look at the cost of a new RockJock axle at around 10k a pop you start to think.
Oh I know it’s not from experiencewell aware. just dont want anyone to get the idea that running even 35s the right way is a cheap endeavor.
Big tires, just for the beach?.changed my mind and I wanna go bigger. What would be the best route for a 37 inch or 38 tire to fit?!?!
This is my friends ride on 38 inch TSLs. It has an 77 F150 44 with 8 lug outers and a 14 bolt in the back. It is running modded 7.5 inch RE long arm (not my choice) and IIRC a one inch body lift. For 38s to work without high lines it does not have as much up travel as I would have liked to give it considering the lift height and rear driveshaft length but compromises had to be made. This is about as inexpensively as you can do it knowing that if you want to do serious rock crawling the front axle is going to be a limiting factor.
At least I get to say, " Ive never been a dumbass". That`ll keep you freaks going for a year. PEACE LOLNever been in mud and had to get the tires a-spinning until they "hook up" to get out of the mud?
you get to say it and it wouldn't be the first lie you've toldAt least I get to say, " Ive never been a dumbass".
with your transmission, 4.88s and current axles you could do 35s at a realistic cost but go to a larger tire than that ... fuhgeddabouditI am no expert,just here to learn. I'm new to jeeps period. Maybe I will drop another 10-15 in it. Thanks Chris and lj for your expertise.
Got it 35s it isFirst rule of running bigger than 35’s, don’t talk about running bigger than 35’s.
Lost me when he referred to his first two CJ's as "Wranglers"...DDDDs on stock axles and brakes. It has a 6" RC LA lift and 2" BB on top.
p.s. A must read.
https://medium.com/@hometownsearch/jeep-wrangler-tj-40-inch-tires-e92eada5e68b
I don't begrudge anyone for building what they want, and I do not care whether he breaks an axle or not. However, that thing on stock brakes is putting everyone else around him at risk.
With your 42RLE 5.38 won't be even close to enough gear for 37's, it's almost not even quite enough for my 35's. With aftermarket axles you can gear more deeply than the Jeep axles can be.Save up for Dana 60's front and rear, this time gear to 5.38 for 37's.
Brakes are really the only thing he NEEDS to change (unless it never goes over 35mph). He admits its an on road only Jeep. With those gears and a stock motor in 2H, even a stock Dana 35 is probably fine. Its clean and looks cool (in a cartoon sort of way). I'm glad he likes it.
Me too. But that's because of the way I drive. He says he babys it and his old CJs apparently survived his driving with big tires which is why I'm guessing he'll be fine, even if me and you wouldn't. Or not...I'd be worried even for a street rig. Heck even with my axles 40's are about the max I'd want.
