I was installing my winch this past weekend, and the mount that I used required that you reuse the factory bolts for the sway bar up front to attach the mount to the frame. Anyway, when I was reattaching the sway bar bolt (that goes into the frame), it looks like the frame-end that the bolt goes into has stripped out. I was tightening the bolt down, and all of a sudden it broke free and started spinning, and I can just drop the bolt in/out of the hole.
Is this something I should try to have fixed? Or will it not cause any issues. 1 of the 2 bolts are on, and both bolts on the other side are on.
If I need to get it fixed, would a mechanic be able to do that?
