Evap Hose Identification
FWIW for the next person, the manifold side was 8mm but the elbow I’m pointing at above measured out at about 6.5mm so back to eBay I go.
We’re you ever able to find the proper sizing or actual line? Mine is just deteriorating from manifold size what should I search for on eBay?
You think I can get a picture of how you installed it did you just plug it right up with no elbows or anything?
Just plugged it in.
I was coming here to create a new post and happened to find this, so it's my lucky day. I'm hoping to get some clarification though, since I've seen a few different sizes posted.
1/4" silicone tube was used to replace the entire line from the manifold to the Leak Detection Pump
1/8" silicone tube to just replace the elbow from the OE tube to the Leak Detection Pump?
5/16" silicone tube to just replace the elbow from the OE tube to the manifold?
for mine,
1/4" silicone tube was used to replace the entire line from the manifold to the Leak Detection and I did not replace the elbow.
. At 2$ a ft, I’d just grab one of each from ebay. Also the silicon will stretch.
Reactions: Serbonze
