connor grimes TJ Enthusiast Supporting Member Joined Oct 24, 2018 Messages 367 Location Los Angeles Jul 10, 2022 #1 Is it possible to upgrade my 4.56 gears to 5.13 gears with only a ring and pinion for front and rear axle? Or will I need new carrier ?
Jerry Bransford Retired to more relaxed pastures... bye. Supporting Member Joined Nov 9, 2015 Messages 29,739 Location Fleming Island FL Jul 11, 2022 #2 New carriers will not be needed. Reactions: connor grimes and pc1p
CherokeeKid Member Supporting Member Joined Nov 27, 2020 Messages 88 Location Cherokee Nation Reservation Jul 11, 2022 #3 Jerry Bransford said: New carriers will not be needed. Click to expand... X2. Gear split is around 3.54/3.73 and numerically lower depending on whether dana 30 or 44 Reactions: connor grimes
OP connor grimes TJ Enthusiast Supporting Member Joined Oct 24, 2018 Messages 367 Location Los Angeles Jul 11, 2022 #4 if i regeared only 25k miles ago is it worth getting the bearing and race rebuild kits with it as well ? or should i just go for the gears
T TRE3TOP Guest Jul 11, 2022 #5 connor grimes said: if i regeared only 25k miles ago is it worth getting the bearing and race rebuild kits with it as well ? or should i just go for the gears Click to expand... Impossible to say without inspection.
M machoheadgames LED turn signal club Supporting Member Joined Jan 21, 2021 Messages 1,908 Location Dallas, TX Jul 11, 2022 #6 If the gear dude has a clamshell puller he can very likely reuse them. Reactions: Jerry Bransford
