I have a 2004 Rubicon with 26,000 original miles, I have a couple of issues I need help on.
The first is, If I turn the key on and off three or four times to prime the engine it starts right up, If I just try to start it normally it takes several tries before it starts. Would that be a fuel pump or sending unit issue?
The other issue is today I had my engine light come on, the code ended up being a misfire on cylinder 2. Could that be an injector, plug, or ignition coil pack?
I also have a little noise from my front drive shaft, I was told it's cheaper to replace it rather than have the u joints replaced where it goes into the transfer case. If that's true, what would ya'll recommend for an aftermarket front drive shaft?
Thanks for the help.
