There is always something about an engine on the host.
And back in the frame rails... Hopefully for the last time.
Tranny bolted up and the transmission crossmember installed.
And the engine is in place.
Clearance on the drives side.
OK @Apparition is this progress enough for you?
at that pace you might have yours running before I finish mine LOL
Might as well modify the crossmember now then. Think about how much it's going to hurt doing it later lol.I must be getting old cause I'm worn the fuck out from muscling it into place. And that was with a floor jack that works.
Could you kill two birds and tuck the belly up a bit more since you have a bit more clearance now?
Doesn’t Wizard recommend the temp sensor for the fan go into the radiator? That’s where mine is.
When I talked to them they would be putting it in the radiator.
My radiator doesn't have a spot for the sensor that I know of but I'll look again. And they never mentioned that to me.
Damn guess I need to call them.
