Hey folks, I've spent the better part of the last year updating things on my '98 tj 2.5l.
List of changes and upgrades for reference:
ArB twin air compressor
0/0 guage BIG 3 wiring
new exhaust manifold, cat, muffler and O2 sensors
New front end -OEM nothing fancy, i figure they work well enough stock and i always figured i could probably drive AROUND the boulder
12k winch (i know, but there's always the option of anchoring the truck)
pretty much every sensor in the engine compartment. TPS, MAF, Oil pressure sensor, power steering sensor, IAC.
New grille, new front fender, new bumper front and rear 15 gallons of extra liquid mounts, pioneer gear, etc. Hopefully at this point the theme is apparent.
I want a high output alternator because I'm trying to buy time when I use power tools, I know it wont catch up to use with the winch, I know I need and intend to install a secondary battery if extended electrical draws are going to be a use case, and i know no matter what size alternator i throw on i'll still drain a battery - keyword here is time, how long can i run the tools i might need for extended periods whilst the jeep is idleing.
The going rate of amps seems to be around 200 for the high end, vetted alternators like Mean Green. I do not mind spending the money on the alternator if it works, but i was hoping for something around 250 AMPs that isnt a re-manufactured bit of snake oil, so i'm hoping some folks have a few suggestions on brands that actually work, and put out the amps that they say they do that come up with a little more amperage than the mean green's advertised 200.
rest assured I intend to put the money into a quality battery for this setup which i am sure is more important than the alternator, but the charge rate over time makes a pretty big difference when you're talking about running a 3000 watt inverter at 50% duty cycle.
