Extreme Sport TJ
From the factory both roll bar and floor were just primed at the time of bolting together then sealer was applied to the edges prior to the paint, that just nicely helps the cause for rusted bottoms on our TJ over the years. Jeep surely played cheap here 🧐.
Here is the shiny ā€œRoll Barā€ - Well it was all shiny before as well except floor mounts had some hairline surface rust around edges where sealer was applied at the factory.
Luckily I got here way before the rust could and hopefully it sorted now for good.
While the seat were out tackled an important safety mod / upgrade. To me this was do it once and do it right, so swapped rear headrests, plastic sleeves / guides and internal metal bracket form a rear seat of a 2013 Jk (2 Door) and grafted on to TJ rear seat frame and result is all OEM fit and finish and most importantly peace of mind šŸ˜Ž. Even stole the pull string bracket from the JK seat for easy pulling seat back šŸ˜€.
šŸ˜‚šŸ˜‚šŸ¤£, one thing is pretty clear, I am very proud of myself for being OCD for things I am emotionally attached to, but you surely are at another level šŸ˜†.
How difficult was taking that dash apart?
Wow I didn’t notice your question until now! It wasn’t hard at all. It was removal of the three nuts on each side by the speakers, I think three or four bolts across the top of the dash under the defrost trim and the thing pretty much lifts up and out. You just have to take the connectors apart where they connect from the firewall to the dash. Here’s a good picture of the backside from my 02. The steering column has to go too but it’s only 4 bolts holding it in.
The refresh looks great! I definitely use my Jeep, but I try my best to keep it looking clean and fresh, so I absolutely appreciate the time in effort you’ve put into the work you’ve done.
Reactions: AutoCrat
Wow, backside of dash looks pretty daunting. Important bit would be to remember what connects where?
This morning only I had hard time remembering stuff that I pulled off couple of months ago.
Thanks for the appreciation, I think TJ wranglers are very close to being collectables especially well maintained and looked after examples. I am planning to keep mine for a very very long time so it’s all worth it for my own peace of mind.
Finally managed to find 4 of these steel beauties from Japan. As per seller these are off of a 2004 JDM specific special edition (Apparently ā€œSuperdry Editionā€œ ). Now need to find one more to complete the set.
I also know another set of these exist in chrome version (again from some special edition) in Japan, I have been trying my best since last April to talk the owner out of it but he doesn't want to part with it.
Reactions: Jamison C
It’s been while, so thought I would check in and say hello to you all lovely people šŸ™‚. Been busy and nothing much happened other than plain simply driving and enjoying my retro looking TJ on OEM steel wheels šŸ˜Ž. There have been much debate all over internet that steel wheels are difficult to balance but my experience so far has been completely opposite. Granted that I only drive on roads so most trail related issues don’t apply in my case, I haven’t encountered any vibrations or wobbles whatsoever while driving at street or freeway speeds. OEM steel wheels rock in my opinion šŸ‘
