There's a lot to be said about this, although its hard to beat a good quality relay. But not having to run discrete wires for every single switch and dealing with all the associated complexity makes a sPOD or similar device attractive - esp. for a retrofit. Unfortunately, the expense seems to be horrid as well for most of the solutions.Most of these don't require a smartphone, but you can use one if you'd like. The smartphone is typically just a way to easily program a controller in a way that is more straightforward than toggling through settings without a display.
Personally I prefer a MOSFET/solid state based switching, which is all programing and heat management and not based on multiple mechanical switches and more wiring for each "push of a button". I wouldn't even really have relays if there were more options since relays hate everything Jeeps are known for ie vibrations, dirt, debris, water, etc. There are obviously major disadvantages since they aren't common, but it's incredibly simple tech compared to the physical makeup of switches and relays, though seemingly simple.
I certainly like the idea of a bunch of relays wired together and properly sealed with a compact switch face compared to the price of the solid state switch devices. However IMO it's to each their own if they'd prefer to buy pre-wired or wire their own. Sometimes you can get a better bang for your buck and form factor from a company that is going to make hundreds/thousands vs 1. I haven't really looked. Sometimes when you piece together your own stuff you can also get better components if you know what you're doing.
Personally it's easier for me to program than it is to do relay logic or some of the older logic circuits that I've seen in so many books, but never once wired myself.
Take apart a few switches and relays and they're seldom a simple device you might see in an old Frankenstein movie, instead they truly are little Rube Goldberg machines.
We went from using MOSFETs to a relay system in an autonomous, remote deployed system. There wasn't anything wrong with the previous MOSFET setup, but we felt we were better off long term with mercury wetted relays. That was 22 years ago, its still running - this is NOT something you want to break as it costs thousands in ship time to go fix/replace the thing. No smartphones though!
