Everything flashes, or just the rear (brake) lights?I did find out that the brake lights work when the hazard button is pushed in.
And they only work when the hazards are on?Everything flashes, or just the rear (brake) lights?
The brake lights work properly when the Hazard light button is pushed down, otherwise they don't work at all. Brake pedal works fine.
The hazard lights and turn signals don't work at all.
Let's start over.no turn signals or hazard flashers, brake lights.
Turn signals and Hazard lights don't work at all, with key on or off.
Brake lights only work with the Hazard button down, with key on or off.
Yes, I was confused at first.Ok the the hazard button down this is the hazard off position (normal driving)
Fuse 27 is listed as MFSW in my 2006 owners booklet. I wrote in my booklets margin that it controls the turn signals, Hazard and brakelights, so I don't forget that.
NskLJ, 27 was it! Checked it before, but decided to replace it and everything is working properly now!! Thankyou!
Also Thanks to LONGpj2 and others for your help!
Do all the parking lights work?
With lights off, press the brake pedal.
Do all the brake lights work, or just the center?
Just the center
Just the center
