I've read a bunch of lift threads, and I think I know what I want to do, but I'm all about getting as much guidance and advice as possible.
2001 Sport, everything's stock. Drives well, but the suspension is definitely feeling its age and mileage (113,xxx miles). No weird tire wear, but an off-center steering wheel, a little bit of drift rightwards, and a somewhat "loose" feel at speed. I'd be willing to bet that every bushing needs to be replaced. At this age and mileage, is there anything I should plan on replacing as a matter of course?
And with the famous last words, "while I'm in there....", it makes sense to replace the shocks and springs with lifty things. I'm very intrigued by @CodaMan's lift, and would like to go in that direction with OME springs, the 3/4" front spacers, the 1/2" body lift, and a JKS adjustable rear track bar.
At this point, I have zero interest in running anything larger than a 31" tire. My off-roading will be limited to fire roads and trails through the local national forests. I have zero interest in rock-crawling. I'm not looking to change control arms, do anything to the transfer case or driveshafts, hack up the console, change motor mounts, or anything else. Is this realistic?
Yeah, I know I'll probably want more at some point in the future (I own Harleys, I deeply, profoundly understand mission creep), but for right now I want a simple 2-1/2" lift.
Fire away, and thanks!
