Likely a dumb question but, for factory fog wiring, which color is ground, which is power? One blue wire, one black. Changing to the Lasfit 3” pod fog lights LED). Thanks!
Avoid cheap or store brand replacements, they don't hold up. If you can't find a Mopar replacement at least go for a premium replacement. I'd check www.rockauto.com for what you need, you'll get an assortment to choose from.Thanks everyone. Look like I have the turn stalk issue. Fogs flicker on and off when any pressure is applied to the stalk lever. Looks like I need to swap it out for a new one. Amazon?
I'm no fan of either, I'd make my selection from someone like from www.rockauto.com or www.summitracing.comHow about the ones from Quadratech or Extreme Terrain?
