Purchased a HP30 from a XJ guy on FB and installed in my TJ. The axle came with an installed spartan lunchbox. Now that I have the axle installed, I can not get the spartan to unlock. It locks up at the slightest right turn and will not unlock even when the wheel is straightened out. Left is normal operation and ratcheting.
With the front end off the ground I can spin the driver tire and it will spin both. If I spin the passenger tire, it won’t spin both. I’m leaning to it maybe out of tolerance specs on the passenger side but that’s all I know to check. Anyone ever experienced this or have any other ideas I should check while the Dif is apart???
