Vtx531
Great restoration. Can you give me any details on your blast cabinet setup? Why glass beads? How did you "clean up" the big parts? What type of paint on the engine, trans, intake? Everything looks really nice.
Good morning,, I bought a cheap sandblast cabinet from Princess auto, in the USA Harbour freight sells the same product. I did some modifications to the cabinet which you can easily find on YouTube. The big change was buying a different gun which solved most of my issues. I like glass over sand as it lasts longer, less dust and reasonably priced.
to clean up the big parts, I first used wax and grease cleaner and then used 3m sanding disks on an angle grinder. Here is an example of what I used and they worked great. Sanding discs
for paint I used VHT for the block and for the valve cover and body I used SprayMax base clear.
VHT Paint
2k epoxy Primer
Spraymax 1k basecoat
2k Clear coat
Any other questions give me a shout, good luck on your project.
Thanks - what gun did you buy? And did you change the syphon tube also? Shop vac hooked up to it?
Very nice job with that relay fuse box. So much better than most 12v electrical mod jobs you see on the internet.
I also finally managed to build my own relay setup and install new headlights. I know everyone has a different view on the type of headlight and I get it. I decided to go with a new glass housing and an H4 bulb for now. Eventually I will try out some oth bulbs but for now I’m pleased with the outcome.
poem bulb sealed sylvania
H4 below with factory harness
H4 bulb with new relay and harness setup. Vey noticeable.
Link to the h4 housings?lookin good!
