B
BabyBass2
Guest
“M
Thats good, but you need to be able to swing the door back and forth. I had to do this on the three TJs I had, if you jack it up with a floor jack, you will not be able to swing the door back and forth while aplying pressure. My idea, which is a bit cumbersome, will allow you to move the door freely from side to side. Matter fact I just got my third TJ, and I had a hard time pulling one of the doors. Is hard to pull them off first, but they will come out if you can swing them. Once they come out, you will have to remove all the corrosion from the pins and the hinges, and you may find a black plastic sleeve inside the hinge that may need to be removed and replaced. Don’t give up, they will come out, you just have to be persistent.TJ Jim pointed out earlier that I should jack up the door and leave it like that under constant pressure while securing it to the roof. At the time I didn't think much of it since my garage ceiling is finished off but then I realized I can secure the door to my garage door frame rails. I can't believe I completely missed them, I'm blind. So I'm thinking a floor jack to the door and a ratchet strap pulling on it that is secured to the rail is definitely something to try. Maybe multiple straps or ropes so it doesn't just go swinging if it comes out and I'm not there.
