Better ask his wife...
I blame my kids mostly, they're young enough that they want me at all their events (and I like to be at them too
I'm gonna try and hit Rampart this weekend just to see how it's driving. See if anymore clutch pedal issues areise.
Your yard reminds me of my grandparents' yard in Arvada and is giving me a whole lot of nostalgia.
Are you replacing the broken line with PVC or HDPE?
Seems like this has been asked over and over in this thread, but I'm seeing if anyone has any new recommendations in the greater Denver area for regearing. For my previous TJ, I used Black Label Off Road in Golden, but it looks like they're out of business. All Seasons 4x4 in Broomfield has also closed shop.
I have a call into The Edge for a quote since it seems like I see them recommended regularly, but if there's anyone on the north side, even up to Loveland, that anyone would recommend, I'm all ears. (I'll stay away from John's 4x4 in Boulder since they were insistent that 4.56s were ridiculous and what I really wanted for 31s was 3.73 gears.)
Specifically, I'm looking for 5.13s and E-lockers in both ends.
More sprinkler repairs for me this weekend![]()
Colorado Axel is 64th and Lowell area. Old dude, all he does is gears and axels knows 4x4s
Thanks for the recommendation. I've been discussing the project with @hosejockey61, so will potentially be going that route.
You probably dont need it--but I can vouch for Mike and his installations. You'll definitely learn a few things too working in his shop. We've regeared both my axles and he's helped me replace some ARB journal orings for my rear locker.
@rasband
It was the clip. But at 0430 I don't have my diagnosis cap on. Just my "crap Ive got to get to work hat."
Aviation.That's an early morning!
New HDPE and reusing most of what I can find. My experience is that pvc gets fragile just after a few years and I think its because the clay swells. It seems the main lines are ok for the most part. There are a few areas I've had to repair, however the swing lines are broken and buried.
I found 10 sprinklers so far in the backyard. I have to find the first one, cap the line, then turn the system back on to build pressure so I can find the next one downstream. Its a bit time consuming. I think there are a few others I am missing, especially along the rock wall.
This one here actually functioned. It just couldn't pop up for obvious reasons. This one is going to be replaced with a port manifold and water decorative grasses and/or shrubs with above ground 1/4" tubing. The upstream sprinkler from this, is located directly below the deck
This one is going to be moved likely to the corner of the yard in the top left of the photo. The swing fitting had broken and there was no sprinkler head found. From the cap you can see in the right puddle, Ill extend with new swing hose about 4-6'.
Similarly, this head was paved over. Once the pavers were removed, the head actually functioned. This one is going to be moved with new swing pipe and will be used in the corner of the yard which is only a couple feet behind me in the photo. I had to break away some roots from the maple tree unfortunately.
The wife is planning on a garden in this area. Ill install another 2-4 port manifold and this will be used to water the garden.
This is a break in the main 1" line. Its directly under roots from the lodgepole pine tree, which is what caused the break I am sure. I'll have to dig this one back a bit towards the pavers and will cap and build another swing. Another 2-4 port and above ground tubing will be used here for landscaping plants.
This one is my favorite. It sounds and looks like another main line break. A raised flower bed was built here and acccording to the neighbor, only a few years ago. So to get to it I am going to have to dig pretty far. Its daylighting in the back near the fence corner. I think I'll dig right in the center of the bed to try and find it, then build a new stand off with another manifold for shrubs that I will plant. We'll see what the root system is doing...
That's an early morning! I will say getting the pedals out was one of the most frustrating parts of my auto swap, it's just all so hard to get to.
Worst game I've ever seen but glad that they got the W
