Hi,
I'm new to the forum, but not new to Jeeps. I'm currently working on a '98 TJ 4.0L I6 sport auto (coming from an XJ and JK). The PO made some curious selections on his lift-- rides well offroad, but on road stability has been a challenge. Money is tight, but I'm saving each month to do one improvement at a time to restore a bit of on road drivability. Given my current situation where should I spend money first? I do all my own work.
Current:
4" lift
Bilstein 5100 shocks
Steinjager crossover steering
Stock control arms
BFG T/A Load E 305/70/r16
The rear axle looks too far forward due to the lift, front looks OK, steering is solid, tracks straight, the jeep wobbles often with some bumps, highway is rather smooth, but still some wobble. The best $0 change I've done thus far is to bring the psi down from 30 to 24. Here's what I'm thinking scenario wise:
1: Upgrade front control arms upper/lower to adjustable
2: Upgrade rear control arms upper/lower to adjustable, pull axle back and rotate into inline position with driveshaft. Will I need to also do SYE at the same time?
3: Delete these tires for load c tires
4: Delete these bilsteins for rancho 5000x
5: Keep stock control arms, and purchase lower height springs
Any tips on what I should do first? I can afford to do one per month (or so).
TIA
Current:
4" lift
Stock control arms
TIA
