Moving from my other thread. Dana 44 gear install with Eaton Elocker And 4.56 Yukon gears — all new.
I have not been able to get the backlash variation within spec. Today I took the carrier out and throughly cleaned the shim, races and case with some brake clean just to make sure there’s not debris. I’ve tried several different sets of shims as well.
I number 1,2,3,4 on the ring gear roughly 90 degrees between each number. What I did was took a bunch of measurements around each point.
2,3,4 all are within .002” of each other.
1 is as bad as .005” different from 2,3,4. Also, between teeth around one there can be a great deal of variation.
1 is always worse every time we install and remove the carrier. Tried different shim values as well pushing the backlash in and out.
At this point, I don’t think I’ve got just a stupid error on my part. Seems like the ring gear or carrier is whacked. We lightly filed and cleaned carrier and ring gear before install — so doubting it’s not seated well but maybe. Also have checked ring gear bolt torque a few times. Set at 55 ft-lbs
Any thoughts? Probably at the point I need to take to a pro to diagnose.
