For those of you that flat tow, Currie makes pretty clean brackets to mount a tow bar to your rig (part number CE-9033TJ). The typical receiver type brackets are pretty bulky and would interfere with the Antirock.
The installation is pretty straight forward but I had to remove my Antirock first for access to the inside of the frame crossmember.
Each bracket is held in place with two bolts, one replaces the existing lower bumper bolt and the other is drilled into the botom of the frame and crossmember.
Bracket held in place with the replacement bumper bolt.
Use the second hole in the bracket to drill the 1/2" hole through the frame.
The new bolt comes with a curved washer and nut to match the curve of the round crossmember.
New bolt, washer and nut installed in the 2nd hole.
With the bracket installation completed I then just needed to reinstall my Antirock.
