I live in Phoenix, AZ. It can get 115+ here in the summer. This past summer, I noticed my '03 Rubicon started running warm at idle if it sat for 10-15 minutes with the AC near full blast.
On a typical 115+ day, the Jeep will run consistently at 208-214 as measured from the OBD port while moving or even temporarily at idle. If I let it sit at idle for 10-15 minutes, the engine will gradually build heat until it pegs out at 225 (generally doesn't get hotter than that). If I kill the AC, the temps will drop back down to 212-214 after 5 minutes or so.
Few things to note, in the past 1-4 years, I've gradually replaced the water pump, t-stat, fan clutch, and radiator all with MOPAR parts. I'm running a 60/40 water/coolant blend (since we don't drop below freezing here). I put less than 3k miles on my Jeep a year, so these components are nearly brand new.
Around the same time I started to notice the warm idle, I also found the air wasn't blowing as cold at idle and struggles to get ice cold unless set to recirc.
I'm wondering if I need my system charged. Possible compressor overload? Any other ideas before I start tearing into it?
