I'd sure like to see the photos when the lift is taken off, and the new one installed...Wow, I'm actually getting close to finishing it! It does actually need a re-gear, even on these 31.7" tires. Hard to believe, but go drive a 42RLE and you'll understand what I mean. The Zj steering isn't necessary, but it's so cheap that I figure why not?
The OME lift is all here and waiting to be installed, I just have to find some time to do it.
Also, I know it's probably unlikely, but you may notice a bit of better performance with the lower suspension. I have the OME suspension with that size tire, and while I could see how a regear would liven up the powertrain, it's not terribly bad now. I leave the O/D off on the freeway until I hit about 55 mph, then I am good to go. I know most would say 4.56 gears would be a waste of time, but I get the feeling it would be just about right with 31.7" tires and the 42RLE. 4.88 would definitely get you on your way quicker, though, no doubt.
