I'm a bit confused about their drop options. How I read it, 0" drop is factory drop 1" drop is lower than factory? Why would you want a skid that sits lower than a factory skid?
Same reason some people run skid drops after installing a lift. Its used to counter vibrations and spending the money to buy a SYE. Trans drop is ~$30 versus doing it right with SYE at ~$200 and an additional ~$200 for a new DC driveshaft.I'm a bit confused about their drop options. How I read it, 0" drop is factory drop 1" drop is lower than factory? Why would you want a skid that sits lower than a factory skid?
https://teraflex.com/shop_items/tj-97-02-1-2-transfer-case-lowering-spacer-kit
“The TJ Transfer Case Lowering Spacer Kit lowers the transfer case to reduce driveshaft vibration caused by a ride height 2” or more above stock – especially on TJ Wrangler models without either a slip yoke eliminator kit or adjustable control arms.”
IMO this is an even better route if you MUST ABSOLUTELY lower your skid. This is doing it a little better than a lowering kit that fits between the skid and the frame. But it begs the question why not just go SYE at the price that you would pay for the skid...
Emailed Jeremy at TDK and he reassured me of what i thought would be his answer. They do make the skids for 03+ Wranglers they just are not isted on the website.
Right I agree with you 100%. SYE all the way, I understand that money doesn't grow on trees, but at some point you have got to say lifting a TJ yet lowering the case is in one way or another wasting money and defeating the purpose behind the lift.Yep, confuses me cause you're raising your jeep so you can lower your TC skid? I can see it if you just want bigger tires for aesthetics, but for actual offroad advantage, I don't get it.
Im sure its the same price as all the others listed on his site; $400. The website quoted me $100 for shipping to my zip.Oh snap, totally going to order one of those. That would make life so much easier, not having to support the transmission and transfer case when removing the skid. You didn’t by chance ask him how much, did you?
I may have to order one. This in my opinion is how the skid plate should have been from the factory.Im sure its the same price as all the others listed on his site; $400. The website quoted me $100 for shipping to my zip.
I would say the ZJ steering is necessary. The factory rod is too thin for any reliability. Hell, mine bent and I don't even know when and where. I hadn't even wheeled it really, only some fire roads while hunting.
You don’t say lol. You’ll be happy with them. Just get the lift on already and drive the thing haha.I decided to return the Bilstein 5100 shocks after a lot of back-and-forth discussion with @David Kishpaugh. I exchanged them for the OME shocks that come with the lift kit in the first place. Turns out these shocks are really designed to give you the best performance and travel with the OME springs. I suppose I should have realized this to begin with, but I'm glad I realized it before installing the lift!
Barely 0.5" of clearance at stock.
My fat finger is a bit fatter than 0.5".
Any reason besides price that you went with the Disconnects vs the Currie Antirock on this build? I'm probably planning something fairly similar to this!
Nice idea...I suppose they then could make a skid that will work with the 241 TC & the 42RLE...Emailed Jeremy at TDK and he reassured me of what i thought would be his answer. They do make the skids for 03+ Wranglers they just are not isted on the website.
He offers it for the Rubi as well. So you are covered.Nice idea...I suppose they then could make a skid that will work with the 241 TC & the 42RLE...
Help me understand all I have read in this thread concerning this skid plate...does it leave the TC in the same location height-wise, then offer 1) a smooth underneath surface to help get over rocks, and 2) a separate frame and cross member that supports the transmission and transfer case, yet allows the skid plate itself to be removed without having to support those?He offers it for the Rubi as well. So you are covered.
