I took my '05 TJ for a drive yesterday to put some miles on it and to help break in the new gears, and evidently I've developed a slight leak at the transmission cooler line quick connector on the passenger side of the lower radiator. I've searched through here, and there is a lot of discussion about the line itself leaking where the hard line meets a soft line connection, but mine appears to be leaking from the quick connector instead. I cannot tell if it's leaking between the fitting and the radiator, or between the line and the fitting.
Is there an o-ring on the line that goes into the fitting that I should replace, or do I need to replace the entire coupler? I'm a little worried about the possibility of cracking the plastic tank when switching out the fitting. Is that concern even warranted?
