I've read all the threads I can find about vacuum leaks and they've helped me a lot so far with checking my vacuum lines. But I haven't run across this issue in any other threads.
Jeep is a 2006 TJ 6 cylinder. HVAC controls and Cruise Control (CC) work fine for a few days. Then CC stops working and air flow only at the defrosters. I let the Jeep sit over night and check the vacuum lines in the morning. I don't find any apparent leaks. When I disconnect the vacuum line, there's vacuum still in the line and I can feel air rushing into the line. When I reconnect the vacuum line, everything works fine; CC works and HVAC controls work. Works fine for a few days and then back to no CC and defrost only. I then pull the vacuum hose, hear/feel the vacuum, reconnect and everything is good for a few more days.
Any suggestions to fix this issue?
Thanks,
John
Thanks,
John
